February 07, 2012, 02:06:31 PM
um, Ian's won tuns (a general build thread too)
48
49
50
51
52
53
65
Topic: um, Ian's won tuns (a general build thread too) (Read 29713 times)
0 Members and 8 Guests are viewing this topic.
Re: um, Ian's won tuns (a general build thread too)
Reply #735 on:
September 07, 2010, 07:21:12 PM »
Quote from: Ian on September 07, 2010, 02:36:55 PM
thanks todd,
i built my cage taller than stock height. and when i put those spreader bars it was way too close to my head. if i wore a hat i would probably touch.
does the end of the tube towards the front have to connect right at the a pillar spreader?
i am glad to hear you built it taller than stock, to many guys build their cages to close to their heads and pay for it when they roll and smack their head on the tubes overhead.
it is not totally neccassary to go all the way out to the corners of the A but it would make it stronger. on that one i did i did not
Reply #736 on:
September 08, 2010, 12:26:57 AM »
yeah Ian I would do what you plan just bring the front contact points inward a bit, that particular section won't make or break in a roll.
what about just carrying the two bars straight forward then maybe down the windshield?
just another option.
burtonjeeplj
Reply #737 on:
September 08, 2010, 09:27:49 AM »
so are we going to be seeing this thing anytime soon?
2005 LJ long armed...progressing to one tons
Reply #738 on:
September 08, 2010, 09:39:34 AM »
no
Reply #739 on:
September 08, 2010, 11:24:48 AM »
those are some good ideas guys. i made my cage taller than stock because I'M taller than stock (6'4") and even after lowering my stock seats an inch, i was still too tall for the stock height.
i just don't want to go to all of the trouble of building a custom cage and then have to worry about hitting my head. i don't care about a top, i'll put a bikini top on later.
now that i'm not making fall crawl, i'm going to do a couple things that i was planning on putting off til later
Reply #740 on:
September 08, 2010, 01:22:50 PM »
Quote from: Ian on September 08, 2010, 11:24:48 AM
like...?
Reply #741 on:
September 08, 2010, 01:35:00 PM »
Quote from: Twisty on September 08, 2010, 01:22:50 PM
like...?
i wouldn't have tired the seats into the cage if i was making fc, would have used the stock ones and done it later
Reply #742 on:
September 17, 2010, 11:26:48 AM »
cage update. its 95% welded.
i will be adding gussets and some trianglation later,
but for now, WYSIWYG
changes from last update is the front winshield v is opposite now, parrellel bars on top from center of "a" to center of "b" (won't hit my head on them now AND allows many options to trianglate later) and tied in rear shock hoop into "c" pillar and then added a spreader bar between them. i'll probally change this solid link to a unboltable flange setup, unless i put my rear suck-down winch on that spreader.
Reply #743 on:
September 17, 2010, 02:33:04 PM »
Reply #744 on:
September 17, 2010, 02:34:01 PM »
that looks really good twist . . . . . i mean ian
Reply #745 on:
September 17, 2010, 02:35:12 PM »
You laugh but I did all the notching last night.
Last Edit: September 17, 2010, 02:36:29 PM by Twisty
Reply #746 on:
September 17, 2010, 02:35:35 PM »
Quote from: jeepgod on September 17, 2010, 02:34:01 PM
hahaha
Reply #747 on:
September 17, 2010, 02:38:41 PM »
I would measure under that shock hoop and try and find a nice cooler that will wedge under there.. Looking good, I may have a chance next week to come down and check it all out
Reply #748 on:
September 17, 2010, 02:43:25 PM »
Quote from: Twisty on September 17, 2010, 02:35:12 PM
i just welded.... tim did all of the heavy lifting.
Reply #749 on:
September 17, 2010, 02:50:27 PM »
Quote from: HEYzipupyourfly on September 17, 2010, 02:38:41 PM
I believe he was plannong on putting the fuel cell there
48
49
50
51
52
53
65
