February 07, 2012, 02:03:14 PM
um, Ian's won tuns (a general build thread too)
43
44
45
46
47
48
65
Topic: um, Ian's won tuns (a general build thread too) (Read 29711 times)
0 Members and 9 Guests are viewing this topic.
Re: um, Ian's won tuns (a general build thread too)
Reply #660 on:
August 10, 2010, 02:57:12 PM »
Nice keep picking at it!
Reply #661 on:
August 10, 2010, 09:23:46 PM »
Many thanks to jerryk fo assisting with my brake lines. Pointed me in the right direction for sure
Reply #662 on:
August 11, 2010, 05:19:23 PM »
anytime ian, just wished we had more time to really crank some work out..it went from 5-9 in about 10 min. it was good to check out your build, its been a while since i seen it..keep up the good work.
-jerry
Reply #663 on:
August 13, 2010, 10:01:38 AM »
i'm probably going to take next week off from work and just surf and work on my jeep. should be a good time. if anyone wants to lend a hand, feel free.
Reply #664 on:
August 13, 2010, 11:04:32 AM »
after doing research i went ahead and ordered up currie anit-rock kits front and rear from summit....
Reply #665 on:
August 17, 2010, 05:45:01 PM »
the best gifts are the ones you buy yourself.
last night timmay and i took 2 stock length tj front drive shafts and shortened both into my new front and rear drive shafts. tim plumbed most of the steering hoses. need to pick up another length (3-4') plus i want plenty of spare hose too.
while running brake line it was brought to my attention that the lines i had been told were inveted flare, wern't... so 50+ bucks later from jegs, adapters are on the way....
modified my tranny shifter. cut and tilted and then welded it back. works great. i just can't use my cutting brake in 2nd or 3rd gear
no problem.
Reply #666 on:
August 18, 2010, 09:03:29 PM »
seacrest...out!
Reply #667 on:
August 19, 2010, 06:23:28 AM »
I think it needs a little triangulation....
webmaster@newenglandjeepz.org
Reply #668 on:
August 19, 2010, 04:02:29 PM »
so i welded today for 7 hours today. time to work on the cage some more.
Bald is beautiful
Reply #669 on:
August 19, 2010, 04:06:47 PM »
progress pics would be nice to see on the welding today you did today
83 CJ7
dave07
Reply #670 on:
August 23, 2010, 10:59:06 AM »
any updates?
Reply #671 on:
August 23, 2010, 11:04:14 AM »
Quote from: BiGdAdDeE on August 19, 2010, 04:06:47 PM
the difference between a bracket that is tacked and a bracket in a photo is ....meh
Reply #672 on:
August 23, 2010, 11:20:48 AM »
john came over and designed a cage with painters tape. i am going to follow 90% of his design.
i bent up an "A" pillar but didn't take a picture. it was late and i was tired and blowing bubbles. the "A" is going throught he dash for a clean look and it will be out of the way too.
Reply #673 on:
August 24, 2010, 08:31:25 AM »
worked with timmay last night on the cage. finished welding in the front. tim took over on the stick welder to weld up a bracket on the cast pumkin. its looking sweet after he gusseted it. (i'll have to take a pic of that) i finished welded the rest of the front. oh, here are some cage pics.
photobucket sucsk, i rotated them all and when i view the album, they are fine, but here they are not rotated....meh...
i wonder what i'll work on tonight...
Reply #674 on:
August 24, 2010, 10:00:28 AM »
axle end of the steering ram mount. brings the spiffy.
43
44
45
46
47
48
65
