February 06, 2012, 12:48:52 AM
Project 5
22
23
24
25
26
27
29
Topic: Project 5 (Read 15956 times)
Re: Project 5
Reply #345 on:
August 16, 2010, 08:23:49 PM »
I finally took the time to remove the bolt I over torqued on the water pump.....
after drilling a gazillion holes in the rotisserie last week I swore I would never drill anther hole by hand, went out and bought a porter-cable minus the tax. Not the best, but it should take care of my needs.
http://www.lowes.com/pd_78742-46069-PCB660DP_0_?productId=3162489&Ntt=drill+press&Ntk=i_products&pl=1¤tURL=/pl__0__s?newSearch=true
$Ntt=drill%20press$y=8$x=33
That is all
79 CJ6 258/T-18/4.1 D-300
Re: Project 5
Reply #346 on:
August 16, 2010, 08:33:12 PM »
very nice
Bald is beautiful
Re: Project 5
Reply #347 on:
August 16, 2010, 10:32:07 PM »
I want even just a smaller benchtop one. Nice buy Chuck!
83 CJ7
Re: Project 5
Reply #348 on:
August 17, 2010, 08:30:53 AM »
Thanks, and the by-product of drilling all those holes I became proficient in sharpening drill bits on the side of a bench grinder.
Re: Project 5
Reply #349 on:
August 17, 2010, 08:34:07 AM »
there you go!
Re: Project 5
Reply #350 on:
August 17, 2010, 05:29:50 PM »
once i bought my drill press i wish i had one years earlier.
nice pick up
Re: Project 5
Reply #351 on:
August 23, 2010, 08:54:49 PM »
When I bought this project I was thinking the fuel gauge wasn’t working or it was low on fuel. I confirmed the gauge wasn’t reading correctly when I remove the tank and it was ¾ full.
Although the fuel tank look fairly new as did the sending unit the PO never installed the tank strap so there was a chance vibration may have caused the sending unit to fail. I cleaned the voltage post and ground on the sending unit and tested it with an ohm meter. It tested out to be good so it was an issue with the wiring, ground, or gauge (maybe all three). I will be installing all new wiring plus testing the gauge on a later date.
I had an extra working sending unit so I thought it may be helpful to show the readings for future reference.
Empty
Half
Full would be around 10 ohms
I will clean the tank and get it ready for paint.
Last Edit: August 23, 2010, 08:57:57 PM by Posimoto
Re: Project 5
Reply #352 on:
August 30, 2010, 09:03:53 PM »
Installed a solid aftermarket diff cover on the rear to match the front, primed and painted.
That is all
Bald is beautiful
Re: Project 5
Reply #353 on:
August 30, 2010, 09:15:51 PM »
Quote from: Posimoto on August 30, 2010, 09:03:53 PM
That is all
it's progress
83 CJ7
Re: Project 5
Reply #354 on:
September 06, 2010, 07:57:02 PM »
Began setting up my york compressor for OBA. I tested the one that came with the 360 I installed and found it had a bad clutch after putting juice to it so I used a good spare I had in my shop.
Although the york has a separate oil reservoir, it still leaks some oil back into the discharge line where it can end up in the tires and such. The basic design features make it impossible to eliminate oil discharge but a oil by-pass mod can help.
I chose to do the mod by removing the head.
Below is the oil passage that needs to be blocked. I filled the hole using a wood screw, easy as that.
Side note: the right of the two non-threaded holes has the oil passage. The side of the case is reflective and there is only one oil passage hole.
When installing the head all bolts must be torqued in sequence starting with the two center bolts (17-26 ft lbs)
Primed in ready for paint.
Re: Project 5
Reply #355 on:
September 07, 2010, 03:03:49 PM »
if you want to ditch those bulky threaded fittings, NAPA has a smaller, barbed fitting that can be put in there place, I can search the part number, pretty sure I have it listed somewhere. One of the issues I initially had was clearence around those fittings.
Edit
you can see it in the bottom of the pic, this was my york post re-build
Last Edit: September 07, 2010, 03:06:10 PM by jps4jeep
Re: Project 5
Reply #356 on:
September 07, 2010, 03:55:17 PM »
Sure if their handy, thanks John.
Re: Project 5
Reply #357 on:
September 13, 2010, 07:44:17 PM »
Used some silver hammered paint on the body it’s not completely mounted but you get the idea.
Disregard the missing WP bolt.
Re: Project 5
Reply #358 on:
September 20, 2010, 08:05:34 PM »
I cleaned and painted the air pump and alternator brackets.
I also cleaned out my garage and coated it with por-15 epoxy. It took all Saturday to move everything out and prep the floor. I didn’t get the base coat down until 7pm. Sunday morning I put the top coat on.
I know some rather not use a floor coating but por-15 has a good reputation and the only negative thing I’ve heard was issues with “hot wet” tires (hot dry and wet warm tires are fine). The source of the complaints I’ve read were customers from the southern states.
Nothing ventured nothing gained.
I hate painting, that is all.
Bald is beautiful
Re: Project 5
Reply #359 on:
September 20, 2010, 09:33:53 PM »
that looks great. amazing results
83 CJ7
22
23
24
25
26
27
29
Project 5
