February 07, 2012, 02:56:53 PM *
Pages: 1 ... 22 23 24 [25] 26 27 28 ... 44   Go Down
Author Topic: My buggy build  (Read 18293 times)
jason m
« Reply #360 on: June 01, 2010, 11:15:40 PM »
what a dumbass that guy is!
I want my money back for that fabrication!
Wait a minute I think that was me!
Nothing to see here moving on...
I was like the pass side came right out, the driver side well thats another question.
Jason.
« Reply #361 on: June 02, 2010, 06:20:15 AM »
So this is just a simple bolt in modification - no fab needed?  Grin
Nice work guys!
« Reply #362 on: June 08, 2010, 08:07:00 PM »
Today was test drive drive day.
All in all it went relatively well.
With the tranfercase in low the transmission shifted into all 3 forward gears, reverse, neutral and park.
Was also able to lean out the motor a little bit.
Unfortunately I had to shut it down due to what I think is a collapsed radiator hose.
Other then that everything went well
now all I need is a front 2 piece driveshaft
« Reply #363 on: June 08, 2010, 10:22:23 PM »
thats great news! Hope that radiator turns out to be nadda!
« Reply #364 on: June 09, 2010, 07:48:13 AM »
Good to hear!
79 CJ6 258/T-18/4.1 D-300
Bald is beautiful
« Reply #365 on: June 09, 2010, 08:01:11 AM »
Video helps.  jason you ain't gotta camcorder and a youtube account.  WE wanna see dam it
83 CJ7
« Reply #366 on: June 09, 2010, 11:57:29 AM »
Sorry no vid it was me myself and I oh and 3 dogs.  They have trouble focusing though.
Have to figure out the radiator hose issue and replace the alternator before I get any vids up
jason m
« Reply #367 on: June 09, 2010, 01:35:44 PM »
No I only have a Cell phone that cant take Pic's Cheesy Plus I was not there for that short blast, I was welding on Seans KOH buggy.
We will get some Pics when Its done, still needs a front drive shaft. Miguel might drop it off at my house this weekend and a two peice drive shaft will be built hopfully buy the next weekend. I know next week will be buisy ( work wise ) so I will see what I can do to it.
Jason.
« Reply #368 on: June 09, 2010, 08:41:58 PM »
A few updates, turn out I had a bad alternator, swapped it out for a 130A spare I had.  Only downside to it is that it only really kicks in charging wise around 900 rpm's so you don't see the full 13-14 volts when idling around 700 rpm's.  At least it didn't cost me anything.
The collapsed hose issue turn out its probably a bad thermostat.  When I removed the hose I thought was bad it had barely any coolant in it.  Now that I think about it could it be a huge air pocket?
« Reply #369 on: June 09, 2010, 09:48:21 PM »
which hose collapsed, upper or lower? pull the t-stat all together see if it happens again
« Reply #370 on: June 09, 2010, 10:46:25 PM »
Upper, I'm just going to put another thermostat in there and run it without the cap this time
« Reply #371 on: June 10, 2010, 08:07:11 AM »
I would put the thermostat in a pan of water and bring it to a boil. If the thermostat is good it should open before the water boils.
Could have been air.
« Reply #372 on: June 10, 2010, 08:48:16 AM »
Good idea I'll put both of the ones I have in there.
Update:
Turn out the thermostat is just fine.  Probably just an air pocket.  Will put it back together and run it without a cap see if that works
« Last Edit: June 10, 2010, 01:29:09 PM by mika401 » Logged
« Reply #373 on: June 10, 2010, 06:44:19 PM »
Little video, YES I need to adjust my roller rockers  Fingers
<a href="http://www.youtube.com/v/lgys6f1nTb4&rel=1" target="_blank">http://www.youtube.com/v/lgys6f1nTb4&rel=1</a>
« Reply #374 on: June 10, 2010, 06:48:28 PM »
And YES I need to seal that exhaust manifold leak as well
<a href="http://www.youtube.com/v/E1aC53etCqE&rel=1" target="_blank">http://www.youtube.com/v/E1aC53etCqE&rel=1</a>
Pages: 1 ... 22 23 24 [25] 26 27 28 ... 44   Go Up
