February 08, 2012, 08:03:34 AM
an engineering design flaw
13
14
15
16
17
18
19
Topic: an engineering design flaw (Read 9796 times)
0 Members and 3 Guests are viewing this topic.
Re: Project Sore Unit
Reply #210 on:
July 24, 2010, 05:55:40 PM »
Yes they were.
Reply #211 on:
July 26, 2010, 11:35:03 AM »
looks better via the internet than it does in person
you better be done before i am
Reply #212 on:
July 27, 2010, 09:38:10 AM »
I like the tube fenders you build.
Besides the cooling benefit is there another reason to run without the inner fenders?
79 CJ6 258/T-18/4.1 D-300
Reply #213 on:
July 27, 2010, 09:40:40 AM »
Quote from: Posimoto on July 27, 2010, 09:38:10 AM
some modify the inner fender to fit with tube fenders. i removed my inner fender and removed the inside part of the tube fender to fit airshocks. downside is dirt/mud can get in easily.
Reply #214 on:
July 27, 2010, 02:24:58 PM »
there will be inner fenders eventually, thats why in most pics, you still see my old fenders kicking around. going to hack them up a bit and try to run parts of them.
mud rover
Reply #215 on:
July 27, 2010, 09:43:59 PM »
looks great john.nice work..when is the planned finish date?
01 jeep Tj
Reply #216 on:
July 27, 2010, 10:35:58 PM »
Johns never finished. He will wrap it up, wheel it twice and rip it all apart again!
webmaster@newenglandjeepz.org
Bald is beautiful
Reply #217 on:
July 27, 2010, 11:14:25 PM »
more boat side pics please.....my favorite part of the build
83 CJ7
Reply #218 on:
July 28, 2010, 08:20:31 AM »
no pics, but I spent a couple hours on it last night. cut and notched all the side bars. in the process of making a jig so that all the tubes will be level and square so I can get away with one solid sheet of plastic. also cut the front mounting feet off the old cage and cut more out of the floor. not sure if I will get to work on it in the next day or two, supposed to be muggy, plus I need to get up to ians to cut some brackets up and junk.
Reply #219 on:
October 11, 2010, 04:54:48 PM »
well, I got some time to make some brackets today, I also took some photo's of the sides and fenders
also here are some pics of the stock bumper I got from Jeff at crown.. prettied it up a little
Reply #220 on:
October 11, 2010, 04:58:52 PM »
here are some of the brackets I made today, these are going to tie the fenders into the rad. hoop
also got the bars that tie the fenders into the boat sides bent and cut, didn't fee like pulling the welder out today, So I'll welded all the small things up this week, finish trimming the floor, trimm all the body mounts, measure for the poly, prime and paint this junk.
Bald is beautiful
Reply #221 on:
October 11, 2010, 06:16:11 PM »
very unique build John. Like it!
83 CJ7
Reply #222 on:
October 11, 2010, 08:21:15 PM »
why are those brackets to tie the tube fenders into the rad hoop three piece, couldn't you just have made one piece ? just curious was it for adjustment purpose ?
Bald is beautiful
Reply #223 on:
October 11, 2010, 08:24:33 PM »
just a guess Jerry but I am thinking it is so he can unbolt it all and he is planning to put a bolt through all 3 peices . Just a hunch but could be wrong
83 CJ7
Reply #224 on:
October 11, 2010, 08:40:06 PM »
Quote from: jerry k on October 11, 2010, 08:21:15 PM
to make it double sheer
There is one thing I can stand is when things are not serviceable, so If I weld the fenders solid to the rad hoop, then should I have to remove the fenders to swap a motor for example, I have to cut something.. by making them as I did, I will be able to unbolt them from the rad hoop, plus it is different, every Tom Dick and Jane just weld crap together, or use a store bought flange.
13
14
15
16
17
18
19
