February 08, 2012, 08:02:49 AM
an engineering design flaw
12
13
14
15
16
17
19
Topic: an engineering design flaw (Read 9796 times)
Re: Project Sore Unit
Reply #195 on:
June 20, 2010, 09:14:28 AM »
lookin' good John
Reply #196 on:
June 20, 2010, 09:57:42 AM »
Holly
thing thing still exists, about time we saw some progress
Reply #197 on:
June 20, 2010, 10:04:46 AM »
that battery box looks hardcore, very nice.
brooksy
A wise man never plays leapfrog with a unicorn
Reply #198 on:
June 20, 2010, 03:25:01 PM »
Boat sides? Are the boatsides done? I am waiting for the boat sides
99 TJ
68 M715
Reply #199 on:
June 20, 2010, 03:35:04 PM »
lookin good john, its nice to see the progress.
Reply #200 on:
June 20, 2010, 10:45:06 PM »
boat sides are not done, had to go to Tony's to get some stock that I needed for a mid-projecdt redesign... worked on it a little day, drivers side is almost there. just too humid to really work on it. plan is tomorrow, cut the hood, cut the pass side rocker pannel off.
Bald is beautiful
Reply #201 on:
June 20, 2010, 11:45:09 PM »
solid plan. I like boat sides
83 CJ7
Reply #202 on:
June 21, 2010, 08:30:28 AM »
Did the bead tweak the 90 degree bend?
Well done and good progress.
79 CJ6 258/T-18/4.1 D-300
Reply #203 on:
June 21, 2010, 09:13:36 AM »
No, I cut that out of a flat piece of 3/16 from a cardboard templet. Ian and Tim saw it before. I used a grinding wheel to score the inside of where I wanted it bent, then I just locked it down in my bench vise and started pulling, hitting it randomly with a mini sledge.
Reply #204 on:
July 24, 2010, 05:28:50 PM »
long over due update here are pics, if you have questions, ask.
Reply #205 on:
July 24, 2010, 05:32:08 PM »
MOAR
Reply #206 on:
July 24, 2010, 05:35:05 PM »
Big D, notice the function in the use of gussets
MORE
Plates to tie the boat sides into the
Last Edit: July 24, 2010, 05:47:38 PM by jps4jeep
Reply #207 on:
July 24, 2010, 05:42:14 PM »
Exhaust parts. using a banks cross over pipe, but I am cutting it up and running the exhaust on the drivers side. I bought this pipe some 4 years ago, figured I would use it for at least the O2 sensor bung.
it'll be 2 1/4 from the header to the muffler, muffler is 2.5 in 2.5 out dyno max circle track muffler, it's small
also bought some J bends to piece and cobble something together. Also going to make it in piece so it will easily be removable
exhaust wrap to prevent vapor lock
adjustable fan control. I had NAutozone search 226203, which is the Hayden part number, this is made by hayden, but different part number and name brand.
Last Edit: July 24, 2010, 05:51:50 PM by jps4jeep
Reply #208 on:
July 24, 2010, 05:45:19 PM »
Your last 3 pics are the same.
Reply #209 on:
July 24, 2010, 05:52:49 PM »
no there not
12
13
14
15
16
17
19
